ransok - Monday, July 7, 2014 5:01 AM:
I am trying to add an extra field (Text Field) to 'Workflow voting Dialog' and show the same in 'Workflow Process History Report'.
Editing 'InBasket-NoteDialog.aspx' which is under ../Client/scripts/InBasket.
I added an extra property(name:min_re Data type : Integer ) to 'Activity Assignment' Item type and added row in 'InBasket-NoteDialog.aspx' like the below:
<td align="right">
<br>
<b aras_ui_resource_key="inbasketvd.min_re"></b> <br>
</td>
<td colspan="3" class="logicalSubSection2">
<textarea name="Comments2" rows="2" cols="80" wrap="on"></textarea>
</td>
</tr>
When I open the Voting dialog it was showing the new field along with an error 'Resource with key inbasketvd.min_re is not found'
Then I added this line <resource key="inbasketvd.min_re" value="Minimum"/> to ui_resource.xml which is under ../Client/xml. Now there is no error. I can see the field.
Is this the correct way of adding a new resource_key?
Now I want to display the value entered in the new field while completing the workflow activity in 'Workflow Process History Report'.
I did the following changes:
1. Edited 'Workflow History Report' method which is attached to the Report.
added the newly created property name to the Query in the method:
<Item type="Activity Assignment" action="get" select="closed_by, closed_on, comments, min_re, path, related_id(name)" >'........................
2. Edited Report Query on the Report and added the new property name.
3. Added a new column in the stylesheet. I added the following line after 'Comments' column.
<td style="font-family:helvetica; font-size:8pt; padding:2px;font-weight:bold; ">Comments</td>
<td style="font-family:helvetica; font-size:8pt; padding:2px;font-weight:bold; ">Minimum</td>
Added this after xsl of 'Comments'
<td style="font-family:helvetica; font-size:8pt; padding:2px;">
<xsl:value-of select="comments"></xsl:value-of>
</td>
<xsl:value-of select="min_re"></xsl:value-of>
</td>
But I can't see the values entered in the new field on Activity dialog in the report. Did I miss anything?
Am I need to do anything else for adding resource_key?
Please help me
Found that min_re's value not being stored in database, showing as NULL. How to solve this? How to make the newly added field's value to be stored in database?
DavidSpackman - Tuesday, July 8, 2014 10:50 AM:
HI Ransok,
I haven't done this before,
When you check the function completeActivity(mode) in InBasket-VoteDialog.aspx. There is an Aras action called 'EvaluateActivity'.
I think you would need to modify this function to add your example input, however I could not find this method to edit.
Hopefully it leads you in the right direction though.
Dave
ransok - Wednesday, July 9, 2014 2:40 AM:
Thank you David,
Unable to find out 'EvaluateActivity' function. There is a Server Method added in Activity Assignment Itemtype with OnAfterAdd Event. Is this saving data into database?
I am trying in the following way:
From function completeActivity(mode) I am calling a server Method to update the Activity Assignment row in database.
1. Added the below two lines before top.window.close(); in function completeActivity(mode)
var serverBody = "<MyAssID_>"+MyAssID+"</MyAssID_><Minimum_>"+this.Minimum.value+"</Minimum_>";
var edit_result = top.aras.applyMethod("Edit-ActivityAssignments",serverBody);
Server Method Code: C#
string ass_id = this.getProperty("MyAssID_");
string min = this.getProperty("Minimum_","");
//return inn.newError(ass_id);
Item ActAss = inn.newItem("Activity Assignment","get");
ActAss.setAttribute("where","[ACTIVITY_ASSIGNMENT].id = '"+ass_id+"'");
Item Res = ActAss.apply();
//return inn.newError("Count::"+Res.getItemCount());
if(Res.getItemCount()!=0)
Res.setAction("edit");
Res.setProperty("min_re",min);
Item FinalRes = Res.apply();
return this;
This is updating the row in database correctly and I am able to see the new field's(min_re) value on the report as well.
But I don't know which is going wrong, it is updating the next Activity Assignment also by adding the same value of the before previous Assignment's min_re to the new Activity Assignment. Like the below:
Here the report is displaying '2' for the Activity for which value is not entered yet. Value in database is updated with the value of before previous Activity'.
Now if I vote and enter min_re's value as 5, I can see the correct value on Report but the Next Activity Assignment is getting '3' (which will become the value of before previous for the new Activity Assignment's min_re) immediately.
Why is this happening?
DavidSpackman - Wednesday, July 9, 2014 11:17 PM:
Hi Ransok,
Repeat activities are cloned from the previous activity.
If you view the activity item type in SQL it might help
SELECT
DCO.ITEM_NUMBER,
A.NAME,
A.ID,
A.[STATE],
A.CLONED_AS,
innovator.ConvertToLocal(A.CREATED_ON,DEFAULT) CREATED_ON,
innovator.ConvertToLocal(A.ACTIVE_DATE,DEFAULT) ACTIVE_DATE,
innovator.ConvertToLocal(A.CLOSED_DATE,DEFAULT) CLOSED_DATE
FROM
innovator.EXPRESS_DCO AS DCO
INNER JOIN innovator.workflow AS WF ON DCO.id = WF.source_id
INNER JOIN innovator.workflow_process AS WFP ON WF.related_id = WFP.id
INNER JOIN innovator.workflow_process_activity AS WPA ON WFP.id = WPA.source_id
INNER JOIN innovator.activity AS A ON WPA.related_id = A.id
--INNER JOIN innovator.activity_assignment AS AAS ON A.id = AAS.source_id
WHERE
DCO.ITEM_NUMBER = 'DCO-00001058'
ORDER BY
A.[STATE],
A.ACTIVE_DATE
You can use an on_active method on the 'initial review' activity in your workflow to check and delete the min_re value
ransok - Friday, July 11, 2014 3:43 AM:
Thank you so much David, it is working now. I added the following lines with OnActivate Event.
ActAss.setAttribute("where","[ACTIVITY_ASSIGNMENT].source_id = '"+this.getID()+"' ");
Item ResAss = ActAss.apply();
//return inn.newError("count: "+ResAss.getItemCount());
for(int a=0;a<ResAss.getItemCount();a++)
ResAss.getItemByIndex(a).setAction("edit");
ResAss.getItemByIndex(a).setProperty("min_re","");
Item Res = ResAss.getItemByIndex(a).apply();
return this;
