Jeroen Bosch - Sunday, July 20, 2014 4:35 AM:
I'd like to suggest to the developers of Aras to remove the current limitation of 32 characters for the names of methods.
Same suggestion for the names of the relationships and maybe others.
Jeroen
DavidSpackman - Tuesday, July 22, 2014 6:46 AM:
Hi Jeroen,
To work around you should be able to modify this yourself in the itemtypes you mentioned.
ie. method itemtype - name property.
Dave
Jeroen Bosch - Wednesday, February 4, 2015 5:07 PM:
Just wanted to share my positive experience of extending the name length for the following item types and attributes:
- Forms: Name
- Item type: Name; but you need also to change the length of the Instance_data attribute
- List: Name
- Relationshiptype: Name
Don't forget to make these changes when upgrading Innovator and *before* moving the data.
Hope it helps.
Jeroen
Jeroen Bosch - Friday, July 25, 2014 8:39 AM:
Excellent!
Thanks.
