SUPPORT Q&A - v10 login error - 'Aras.Common.Cryptography.RSACryptoHelper'
fabiof - Friday, August 1, 2014 3:01 PM:
Fresh install of v10.0 on windows 7.
When logging in as admin for the first time receive following error:
The type initializer for 'Aras.Common.Cryptography.RSACryptoHelper' threw an exception.
edmoreirabr - Saturday, August 2, 2014 10:35 AM:
Before to setup, please double check the IIS Requirements:
Another point: Confirm if Aras Application is running with Aras Innovator AppPool ASP.NET 4.0 and if this application pool is set to TRUE to run 32bits applications.
