SUPPORT Q&A - Installed Innovator 10, is there a demo database availble
Paul - Tuesday, September 2, 2014 8:36 AM:
I am totally new to Aras Innovator. I just installed Innovator 10 (build 5846) and was wondering if there is a DEMO database I can use. I can see a Demo System (Alternative) database, demo93_v2.zip, Build 930-2 but will that work with Innovator 10?
There is also a Demo Database (Standard Solutions Plus), Aras10-0-Extended-Demo DB v1-6.zip, Build AB10.1-6 but this looks like someting that should be installed on top of the Demo System (Alternative) ?
Anyone?
DavidSpackman - Wednesday, September 3, 2014 11:21 PM:
Hi Paul,
Demo System (Alternative) -
Build 930-2 - No this will not work in 10.0
I don't believe a version currently exists that will run on 10.0
Demo Database (Standard Solutions Plus) -
This is a standalone install for Aras 10.0
I have not tested, but the instructions under Build AB9.4v2 "How To Load the ArasSolutionsDemo940 - Step-by-Step v1.pdf" should be suitable to setup the demo. (Just replace 940)
Paul - Monday, September 8, 2014 4:15 AM:
Great. Thanks David !!! I will give that a try :-)
