didonato - Monday, September 15, 2014 9:18 AM:
Does anyone know how to duplicate the Part BOM Structure and use it for another Item type. I created another item type called "delivered components" that are basically parts with serial numbers. These "delivered components" can also have other "delivered components" inside of them like a BOM, which I have working, but I don't know how to display them in a "BOM Structure" view. Any help?
Dominic
DavidSpackman - Monday, September 15, 2014 10:04 PM:
Hi Dominic,
Have a look at the RelationshipType for Part MultiLevel BOM.
Under the Relationship View tab you can see that a form called Part Multilevel BOM is called.
That form contains HTML code to generate the multi level table.
Looking at the code you will see that it calls a method called PE_GetMultilBom
That method calls a SQL item (stored procedure) called MultiBom_GetCompleteBom1 that returns the part structure.
(Note that MultiBom_GetCompleteBom1 also calls another SQL item called MultiBom_GetCompleteBom2
I would copy each of these items and customise for your itemtype.
Dave
(Checked on Aras 9.3 SP9)
didonato - Tuesday, September 16, 2014 11:34 AM:
Thank You!!!
