DEVELOPERS FORUM - AML for Part Goal
robos - Saturday, September 20, 2014 5:51 PM:
I try to insert cost goal with the following AML :
<AML>
  <Item type="Part" action="merge" where="item_number='115150'">
    <item_number>115150</item_number>
    <name>TEST</name>
    <Relationships>
      <Item type="Part Goal" action="add">
        <related_id>
            <goal>Cost</goal>
            <actual_value>2018.69</actual_value>
        </related_id>
    </Relationships>
</AML>
And I am getting following fault :
<![CDATA[Cannot insert the value NULL into column 'GOAL', table 'InnovatorSolutionst.innovator.PART_GOAL';....
Why is that ? GOAL field in AML is properly populated ?
And next question, how would I construct AML if I would like to use on Part Goal item merge instead of add ? I have to update actual costs regulary because they do change over time.
Thanks for your help !
Bostjan
DavidSpackman - Sunday, September 21, 2014 10:36 PM:
Hi Bostjan,
Your query was not quite correct.
This should work for your initial query:
<AML>
    <name>TEST</name>
    <Relationships>
        <goal>Cost</goal>
    </Relationships>
</AML>
To answer your second question, all you need to do is find a property that is relevant for the item you want to update, in this case we know goal will also be cost.
Note, I have set version to 0 for the Part item, this will prevent a new generation being created each time you update the cost. Setting this will depend on your own requirements.
<AML>
  <Item type="Part" action="merge" where="[Part].item_number='115150'" version="0">
    <name>TEST</name>
    <Relationships>
      <Item type="Part Goal" action="merge" where="[Part_Goal].goal='Cost'">
        <goal>Cost</goal>
        <actual_value>2058</actual_value>
    </Relationships>
</AML>
Dave
robos - Monday, September 22, 2014 2:29 AM:
Hi David,
Thank you for quick and very valuable answer !
Now it works as expected.
Best regards,
Bostjan
