SUPPORT Q&A - Error 500.19 and then 404.3 after new installation of 10.0
mlistberger - Tuesday, October 14, 2014 7:56 PM:
Trying a new install of Aras 10.0 and am running into some issues.  Server: Windows 2012, IIS8, .NET Framework 4.5, .NET Framework 3.5.
Install proceeds without issue but when trying to access the website the first time I received this error:
HTTP Error 500.19 - Internal Server Error
The requested page cannot be accessed because the related configuration data for the page is invalid.
Detailed Error Information:
Module
   IIS Web Core
Notification
   BeginRequest
Handler
   Not yet determined
Error Code
   0x80070021
Config Error
   This configuration section cannot be used at this path. This happens when the section is locked at a parent level. Locking is either by default (overrideModeDefault="Deny"), or set explicitly by a location tag with overrideMode="Deny" or the legacy allowOverride="false".
Config File
   \?C:Program Files (x86)ArasInnovatorInnovatorweb.config
Requested URL
   localhost:80/.../
Physical Path
Logon Method
   Not yet determined
Logon User
   Not yet determined
In my research I found that I needed to allow handler overrides at the default web site which I did by modifying C:WindowsSystem32inetsrvconfigapplicationHost.config to change the ‘deny’ settings to ‘allow’.
    <sectionGroup name="system.webServer">
            <section name="handlers" overrideModeDefault="Deny" />
            <section name="modules" allowDefinition="MachineToApplication" overrideModeDefault="Deny" />
Now I’m receiving this error:
HTTP Error 404.3 - Not Found
The page you are requesting cannot be served because of the extension configuration. If the page is a script, add a handler. If the file should be downloaded, add a MIME map.
Can anyone point me in the direction of a solution?
Thanks!
Michael
