DEVELOPERS FORUM - ARAS 10 Tip : Form Fields in IE and Firefox
Phil - Thursday, October 16, 2014 3:36 PM:
In transitioning to ARAS 10, I found that the vast majority of my javascript form code had issues.  The main reason for these issues were caused by the form field values not behaving the same way between Firefox and IE.
Below is a simple little trick I used to get around this issue that worked very well in my case:
<code>
var browserIndex = 0;  //default to 0 for IE, will change to 1 if Firefox
if(document.getElementsByName("field_name_here").item(1)){browserIndex = 1;} //changes index to 1 for firefox
var value = document.getElementsByName("field_name_here").item(browserIndex).value;  //get your form field vals
</code>
