DEVELOPERS FORUM - [Multilevel BOM Report] - Quantities issues
Xavier Bertschy - Tuesday, November 4, 2014 8:22 AM:
Hello all,
I have just noticed a quantity issue with the Multilevel BOM Report, when an item is repeating itself in different Products the quantity attribute is always the same, see the following screenshot:
The BOM structure TAB: (the quantities are correct)
The Costing Report: (quantities are still correct)
The Multilevel BOM Report: The quantities are now wrong, the item Part2.CATPart should be instantiatedt twice under the Product1 and 3 times under the Product2.
I haven't updated the Multilevel BOM Report and the AML query of the report seems to work fine, I've checked it in with AML studio.Does anyone has also this quantity problem? Is it an error with the XLS stylesheet?
Xavier
[email protected] - Tuesday, July 26, 2016 8:37 AM:
I have the same issue with with 11SP5. Does anyone have a solution to this?
Paul
edonahue - Tuesday, July 26, 2016 10:22 AM:
Hi Paul,
This issue is being reviewed for a fix in a future release of Aras Innovator. I recommend contacting Aras Support, as they may be able to assist subscribers with a patch for this behavior.
