jsnosal - Thursday, November 6, 2014 10:12 AM:
Is there a way to pull the the data out of the relatedItems in the AML query? I'm trying to build a report that shows all the affected parts on an AML change. I'm just having trouble getting the the relationship data out of the part data. So I want to do a where used on the Manufacture Part, then get the details on the Parts its attached to. Similar to a multi BOM query, but the top line is a where used instead of a get.
Manufacture Part > Part
Current Query
<Item action="getItemWhereUsed" type="Manufacturer Part" id="123456ABC">
Query I'm Trying to Get to Work
<relatedItems>
<Relationships>
<Item type="Part BOM" select="sort_order,quantity,reference_designator,related_id(item_number,name)"/>
</Relationships>
</relatedItems>
Current Results
<SOAP-ENV:Envelope xmlns:SOAP-ENV="schemas.xmlsoap.org/.../">
<SOAP-ENV:Body>
<Result>
<Item type="Manufacturer Part" id="123456ABC" icon="../Solutions/PLM/images/Icons/16x16/16x16_ManufacturerPart.gif" keyed_name="Manufacturer Part - 02-2-REV1 - 1.3" loaded="1">
<relatedItems>
<Item type="Part" id="654654654" icon="../Solutions/PLM/images/Icons/16x16/16x16_Part.gif" keyed_name="Part - E006 - 1.3" />
<Item type="Part" id="987987799" icon="../Solutions/PLM/images/Icons/16x16/16x16_Part.gif" keyed_name="Part - E007 - 2.4" />
</relatedItems>
</Result>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Eric Domke - Friday, November 21, 2014 11:11 AM:
I am a particular fan of using a SQL in clause to handle these sorts of situations. In particular, something similar to the AML below should get you what you are looking for.
<id condition="in">(select source_id from innovator.[PART_AML] where related_id = '123456ABC')</id>
<Relationships>
</Relationships>
