SUPPORT Q&A - Error on 3D CAD Conversion
Thofste - Friday, November 14, 2014 2:33 AM:
Hello All,
If got some issues with running the cad conversion tool in 10.0 SP4.
I'm getting the following message, i hope some had the same issues en good help me resolve it.
System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: Server kan de aanvraag niet uitvoeren. ---> System.Exception: Error occurred during conversion: Exit Code:1
 Command line arguments were: --input "C:Program Files (x86)ArasInnovatorConversionServer empA1BC9E45E9634DDEB02E27927B03DD0COS90_A00_DRW.prt" --input_pdf_template_file "C:HOOPS Converter emplatesBlank_Template_L.pdf" --output_pdf "C:Program Files (x86)ArasInnovatorConversionServer empA1BC9E45E9634DDEB02E27927B03DD0COS90_A00_DRW.pdf" --output_png "C:Program Files (x86)ArasInnovatorConversionServer empA1BC9E45E9634DDEB02E27927B03DD0COS90_A00_DRW.png" --output_png_resolution "150x150" --camera_default --output_logfile "C:Program Files (x86)ArasInnovatorConversionServer empA1BC9E45E9634DDEB02E27927B03DD0COS90_A00_DRW"
 View the following log for details:
14-11-2014 8:14:16: Consume ArasCadConverter data was started.
14-11-2014 8:14:16: System.Web.Services.Protocols.SoapException: Server was unable to process request. ---> Aras.Server.Licensing.FeatureHasNoLicensesException: Exception of type 'Aras.Server.Licensing.FeatureHasNoLicensesException' was thrown.
   at Aras.Server.Licensing.LicenseManager.ConsumeLicense(String featureName) in D:BuildsInnovator.Builds6015-Innovator-RELS10-0InnovatorServersrcCoreLicensingLicenseManager.vb:line 240
   at Aras.Server.Licensing.LicenseManagerWebService.ConsumeLicense(String featureName) in D:BuildsInnovator.Builds6015-Innovator-RELS10-0InnovatorServersrcCoreLicensingLicenseManagerWebService.vb:line 50
   --- End of inner exception stack trace ---
   bij Aras.ConversionFramework.Converter.Hoops.HoopsConverter.HandleConversionError(Int32 exitCode, String commandArguments, String hoopsConverterOutput)
   bij Aras.ConversionFramework.Converter.Hoops.HoopsConverter.CallNativeConverterAndGetListOfResultFiles(String fileName, String fileExtension)
   bij Aras.ConversionFramework.Converter.Hoops.HoopsConverter.Convert(IDictionary`2 filePaths)
   bij Aras.ConversionFramework.Converter.VaultFileConverter.Convert(ConversionContext context) in d:BuildsInnovator.Builds6015-Innovator-RELS10-0InnovatorCompilableCodeConversionFrameworkConversionBaseVaultFileConverter.cs:regel 38
   bij Aras.ConversionFramework.ConversionServer.ConversionService.Convert(String taskAML) in d:BuildsInnovator.Builds6015-Innovator-RELS10-0InnovatorCompilableCodeConversionFrameworkConversionServiceConversionService.cs:regel 98
   --- Einde van intern uitzonderingsstackpad ---
   bij System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
   bij System.Web.Services.Protocols.SoapHttpClientProtocol.EndInvoke(IAsyncResult asyncResult)
   bij Aras.ConversionFramework.Proxy.ConversionService.EndConvert(IAsyncResult asyncResult) in D:BuildsInnovator.Builds6015-Innovator-RELS10-0InnovatorCompilableCode\_CommonFilesConversionServiceConversionService.vb:regel 81
   bij Aras.Server.Core.InvokeStandardConverter.ConvertCallback(IAsyncResult ar) in D:BuildsInnovator.Builds6015-Innovator-RELS10-0InnovatorServersrcCoreInternalMethodsInvokeStandardConverter.vb:regel 78
Best Regards,
Tom Hofste
