SOLUTION - PROGRAM MANAGEMENT - Unable to add ItemType to TOC
csimpson - Monday, December 22, 2014 5:32 PM:
Hello,  I'm having trouble adding an ItemType to the TOC. I am not getting the same results as the tutorial "Basic Admin Navigation." From the ItemType (editting) dialog box for "MyNewType" I do the following:
MyNewType > TOC Access (tab) > Pick Related (from dropdown)> New
Nothing happens when I click "new." I cannot add anything to the list. If I select "Create Related" from the drop down, then I can create a new entry for TOC Access. However, I want to give access to existing Identities. I want to give "Administrators" access. It seems like there may be a bug?
I'm using Aras Innovator v10 on Windows 8.1 via Firefox.
Thanks for the help!
DavidSpackman - Monday, January 12, 2015 1:19 AM:
Did you resolve this?
Here is what my screen looks like when I choose Pick Related. I get the Search Dialog browser pop up.
From there I just need to choose an Identity, and then choose which category they will see the item under the TOC.
You can look into this more by looking at the TOC itemtype and the it's properties.
Dave
