DEVELOPERS FORUM - ARAS 9.3 in Internet Explorer 11
jsnosal - Tuesday, January 13, 2015 11:24 AM:
Is it possible for ARAS 9.3 to work inside of IE 11? I know that ARAS 11 works with IE 11, but we need more time to make the migration to a newer version of ARAS. While IT is wanting us to move to IE 11. With the testing I have done so far, I have had trouble with getting it to work. If I have the URL in compatibility mode, I get an error saying it only works with IE 7 +. If I remove it from the compatibility view, then I get an error saying I need to review my .NET settings. Any ideas on how to or if ARAS 9.3 will work with IE 11. Thank you for your help.
DavidSpackman - Friday, February 6, 2015 8:40 AM:
I don't believe this is supported by Aras.
Even if you can trick the client into running on IE11 you will run into other errors.
Dave
[email protected] - Friday, February 13, 2015 8:11 AM:
As far as I understand it, you need at least 9.4SP2 to work with IE11.
We've been running with IE10 until our upgrade is put into place.
