DEVELOPERS FORUM - Upgrading from Innovator 10 to 11 without subscription
Jeroen Bosch - Friday, January 23, 2015 6:23 AM:
Hello everybody,
I am currently running Innovator 10 with Firefox ESR (works perfectly).
Aras has just released Innovator 11 and in the release notes for Innovator 11, it says:
2 Upgrading from Previous Releases
There are multiple potential states from which a Subscriber may wish to upgrade to Aras Innovator 11.
1. Aras Innovator 10 is running in production and you wish to upgrade to the Aras Innovator 11 release
2. You are running a version of Aras Innovator that is previous to release 10
The following sections will provide you guidance as to how to upgrade from any of the three described states.
2.1 Upgrading to Aras Innovator 11 from Aras Innovator 10
For customers with an active Premiere Subscription, Upgrade Services are available to migrate your production Aras Innovator 10 (any service pack) version directly to Aras Innovator 11.
Customers with an active Premiere Subscription can request Upgrade Services by contacting Aras Support at [email protected].
2.2 Upgrading to Aras Innovator 11 from Earlier Releases
Customers with an active Premiere Subscription should contact Aras Support at [email protected] to discuss the available options.
How can I upgrade to 11 as I don't have any active subscription?
Also, I would like to know how to access the (D)FMEA module in Innovator? Does it require a subscription?
Jeroen
Jeroen Bosch - Tuesday, January 27, 2015 7:55 AM:
is it such a difficult question to answer?
zahar - Tuesday, January 27, 2015 11:16 AM:
Jeroen,
Your question is mostly business than a technical question.
Generally as non subscriber you have 3 options:
  1. Become an Aras subscriber
  2. Order an upgrade project
  3. Export and import your implementation from 10 to 11 manually
Jeroen Bosch - Tuesday, January 27, 2015 12:39 PM:
Jeroen,
Thanks Zahar.
I agree that the first two options are business but the third one is technical so relevant for this forum.
Any hint how to do this and any idea if 10 & 11 configurations are compatible?
Jeroen
zahar - Tuesday, January 27, 2015 12:54 PM:
Jeroen,
I don't think i have easy step-by-step instructions, you need to understand Aras DB before starting with this project or use services of others who has this knowledge.
When we upgrade our own demo databases between different versions:
  • we analyze itemtypes that we are using and make needed changes in destination database
  • after that we create packages for our own customization and import it to destination database
  • after that we export all the data and import it to destination database
Jeroen Bosch - Wednesday, January 28, 2015 4:46 AM:
Jeroen,
Zahar,
When you say:
  • "we analyze itemtypes that we are using and make needed changes in destination database"
does it mean that you might have changed the "out of the box" Innovator's item types?
If you are confident that you didn't change them, could you safely skip your first step of migration?
Thanks again
Jeroen
Jeroen Bosch - Wednesday, February 4, 2015 4:12 PM:
Zahar,
I need again your help.
I am trying to create my package definition to export it from Innovator 10 and import it in 11.
Is there a way to populate "package groups" automatically and not manually by entering the "name", "element id" and "element type" for each configuration?
(I have tried without success to use the search capability, either simple, advanced or AML flavor).
I hope so, because the manual way of  creating the package group is error prone, imho (for example, when you create a new form or method or rename an existing object, you need to remember to update the package group.
Also, I cannot imagine to do this manually if I have a configuration with a hundred or more objects to export.
Thanks again,
Jeroen
zahar - Wednesday, January 28, 2015 10:02 AM:
Jeroen,
Not really. Don't forget this is possible that Aras change something in the ItemType definition. Added or removed some attributes.
If you using other than PARTPART BOMDOCUMENTS items types like Workflow and ECO's this is something that you need to understand Aras db structure, cause change management module is more complex.
If you didn't changed the ItemTypes i don't see why you have problem to reimplement you 10 DB on 11?
The DB you trying to migrate is one single user db? or this is enterprise db?
zahar - Wednesday, February 4, 2015 8:42 PM:
Search for item and then select Tools->Admin->Add to Package definition
Jeroen Bosch - Thursday, January 29, 2015 5:14 AM:
Thanks Zahar.
I am using Innovator for prototyping so it is not an enterprise database which would require a subscription of course.
I will try to upgrade to 11 and keep the community posted.
Jeroen
Jeroen Bosch - Thursday, February 5, 2015 1:45 AM:
Super.
I wish that I didn't have to ask this basic question in a developers forum but I have search the existing documentation and this forum first.
Looks like "Just Ask Innovator", but also the user manual which comes with the import/export tool, need to be updated for at least this package definition topic
Thanks.
Jeroen
zahar - Thursday, February 5, 2015 3:49 AM:
Actually this is documented in
 Package Import Export Utilities.pdf
in section (atleast in Aras 10 documentation):
3.6 Creating a Package Definition from the Aras Innovator UI
Jeroen Bosch - Thursday, February 5, 2015 2:05 PM:
You are totally right, it is there but under a section which, and this was my mistake, was devoted to the creation of a package definition and not to add items types (and other configurations objects) in the package definition.
Any way, I have managed to export my package.
My next step is to export and import the data.
Jeroen
