SUPPORT Q&A - File Check In and Check Out Missing in 11?
Phil - Tuesday, March 3, 2015 1:49 PM:
Unless I am missing something, I am unable to figure out how to enable File Checking In and Checking Out in ARAS 11.0 .  It does not appear as a right-click option anymore, nor can I find it on the new file management pop-up window (when you click on the blue paper icon).
Has this been omitted from this release?  I know file management has been redesigned in this release, but I can't imagine that the ability to check out, and check back in files has been completely removed.
Thanks for the help.
Peter Borsje - Saturday, May 9, 2015 3:33 PM:
Hi Phil
There is no check in and check out of files anymore in 11. You just remove the old file and attach the new file.
Peter
jose - Friday, October 23, 2015 4:15 AM:
Hello Phil,
I already found this issue, very strange and can not believe it has been removed because aras documentation still remains same way.
Did you found how to manage it? any solution found?
Thanks for the feedback if available.
jose - Friday, October 23, 2015 4:17 AM:
Hi Phil
Any solution found? I have the same problem and can not believe it has been removed. Aras documentation has not been changed this way....
Thanks for your feedback if available.
Peter Borsje - Friday, October 23, 2015 5:23 AM:
Check-in and check-out has been removed.
There is a design document available @ Aras how the new file handling works in 11. It has been drastically changed.
The title of the document is: "File Handling Updates Technical Document" Aras innovator 11
Please request this document at aras support.
