DEVELOPERS FORUM - Disable Server event execution in code
yogesh_kudalkar - Monday, April 13, 2015 9:15 AM:
I want to delete an Item, but before delete I want to check some conditions. I cannot use onBeforeDelete event as this event does not get fired if there is this item is a related item. So I am using onDelete event, but when I am trying to use this event, in the method code after the condition is proper I am deleting the the item. But in this case once again the onDelete server event is getting called recursively.
In code, I tried setting the serverEvents = 0, while deleting the item. But it is somehow not working.
Is there any other way for this?
edmoreirabr - Thursday, April 16, 2015 4:56 PM:
Yogesh, in your code we need to inform:
obj.setAttribute("serverEvents","0");
Could you share the piece of code when you're trying to do this?
Regards
yogesh_kudalkar - Friday, April 17, 2015 1:08 AM:
Hello Edson,
Thanks for the reply.
I tried with setting "serverEvents" to "0" but it does not work for functionalities other than "get" operation.
If I try it with onDelete event, and tried to delete the item in the code written in onDelete, then the event method is called recursively.
I have found the work around for this that instead of calling the "delete" action, now I am deleting the item from DB itself.
Yogesh
