DEVELOPERS FORUM - How to add Viewable to existing CAD file using IOM APIs
Rahul. - Friday, May 1, 2015 8:02 AM:
Hi Friends
I want to add  viewable files to existing CAD files in aras using IOM APIs.
If anyone have code for that then please share it or guide me to how to do that.
Rahul
DavidSpackman - Monday, May 4, 2015 7:25 AM:
Example for a new file (C#)
            // Edit the CAD item
            Item docItem = this.newItem("CAD","edit");
            docItem.setID("561D1A6CF3E143D2B56618B68789C284");
            // Create the File item and set the path to the file.
            Item fileItem = this.newItem("File", "add");
            fileItem.setProperty("filename", "Test File.pdf");
            fileItem.attachPhysicalFile("C:\Aras\WorkingDir\Test File.pdf");
            // Link the file to the File property
            docItem.setPropertyItem("viewable_file", fileItem);
            Item results = docItem.apply();
            if (results.isError())
                // Error handling
                return inn.newError("Error: " + results.getErrorDetail());
            } else {
                // Success
            return this;
Rahul. - Monday, May 4, 2015 1:15 PM:
Thanks David for quick reply &  Help :-)
Rahul Dixit
