Jan Cvek - Friday, May 29, 2015 7:37 AM:
Hi All
I get
really annoying error occasionally and I have no idea what is the cause of the
error. The error occurs for no apparent reason. I did a form with some buttons
which have set field event on click (it could be some other event). Events
runs java script methods which have no errors and work perfectly. Form and
buttons act like normal. However, when I run form repeatedly in short time
(because of testing) It could happened that when click on button with set field
event, I get an error (bottom picture). Since this time this error occurs every
time when I click on any of button which have set field event! It doesn’t help
to restart the Aras in browser as well as restart the server. Error then
suddenly disappear with no reason usually in about 1-12 hours. Thereafter
everything work perfect and field events no longer occurs error.
It is really annoying
because it repeats and I don’t know what the cause of the problem is. Does have
anybody similar problems or have idea what is going wrong?
Thanks for the help,
Jan Cvek
arnaud.chaussard - Wednesday, June 3, 2015 5:23 AM:
HI !
When testing, do you mean changing javascript methods behind the events and reopen the form ? If so the only way to secure the forms behavior is to remove the browser cache from history or the dev tools.
Jan Cvek - Thursday, June 4, 2015 3:33 AM:
Hi!
Yes I mean like you wrote and you have right! I cleared browser cache and error disapeared! This solve my problem.
Thank you!
Jan Cvek
