DEVELOPERS FORUM - Resetting your sequence when using a year
Thofste - Monday, June 15, 2015 8:12 AM:
Hi all,
I'm trying to build a sequence and using the year as a prefix.
After each year the sequence needs to restart a beginning with 0 or 1.
After running and debugging the script it will hang.
When starting a new action and click on save the following server method will start.
if (this.getAction() == "add")
 //System.Diagnostics.Debugger.Break();
//Get the prefix of the sequence who needs to be reset every year
 Item res_seq = this.newItem("sequence","get");
 res_seq.setProperty("keyed_name","aer_action_8D");
 res_seq = res_seq.apply();
 string prefix_seq = res_seq.getProperty("prefix","");
 //Get current year
 string Year = DateTime.Now.Year.ToString();
 Year = Year + "-";
 //If the prefix isn't equal change the prefix and reset
 if (prefix_seq != Year){
  res_seq = this.newItem("sequence","edit");
  res_seq.setAttribute("where","[sequence].name='aer_action_8D'");
  res_seq.setProperty("prefix",Year);
  res_seq.setProperty("current_value","1");
//Get next Sequence and use the field item_number to put it in.
 string nextseq = inn.getNextSequence("aer_action_8D");
 string item_number = this.getProperty("item_number", "");
 this.setProperty("item_number",nextseq);
return this;
When the if statement is skipped it works, and when we skip the getNextSequence (putting the last three lines in comments) it works and it's changing the prefix correctly.
If tested and set prefix on 2014- and then running the script.
I hope some one has done something like this before and could help me.
Best regards,
Tom Hofste
Thofste - Wednesday, June 17, 2015 1:55 AM:
Hi All,
This is a solution but could someone tell me why you can't use the inn.getNextSequence directly after changing the Sequence.
 //Get current year and set prefix variable
 string res_prefix = Year + "-";
 if (prefix_seq != res_prefix){
  //Reset the sequence
  res_seq.setProperty("prefix",res_prefix);
  //Build the first sequence it doesn't to get te sequence after a change
  this.setProperty("item_number",res_prefix + "001");
 } else {
 // Get current Item Number to set sequence
return this;
Best regards,
Tom
