DEVELOPERS FORUM - Specify search on property
handpuppet - Monday, July 20, 2015 11:27 AM:
I have an ItemType named "Document" that has a property called "project".  The project property is itself an item that has an ItemType as its data source.  I attempt to set an Item below and specify the search term I want which is "FCF".  All I get is an error saying "Not a single Item" and I cannot figure out what I have wrong.  Any help greatly appreciated!
Item query = this.newItem("ThisProject", "get");
query.setProperty("project_name", "FCF");
query = query.apply();
this.setProperty("project", query.getProperty("project_name"));
this.setPropertyCondition("project","in");
return this;
zahar - Monday, July 20, 2015 12:55 PM:
Use the ID of the project and not it's name:
if (query != null && !query.isError() && query.getItemCount() > 0) {
this.setProperty("project", "'", query.getItemByIndex(0).getID() , "'");
return this;
handpuppet - Monday, July 20, 2015 1:21 PM:
This worked, thank you very much!
My only other question would be, is there any way to set the property "project_name" with more than one value?  Currently, I just have the value "FCF" which works.  I tried several different ways to add a second value with no success.
zahar - Monday, July 20, 2015 1:27 PM:
query.setProperty("project_name", "'FCF'");
query.setPropertyCondition("project","in");
string ids = "";
for (int i = 0; i < query.getItemCount(); i++)
ids += ((!string.IsNullOrEmpty(ids)) ? "," : "") + "'" + query.getItemByIndex(i).getID() + "'";
this.setProperty("project", ids);
return this;
handpuppet - Monday, July 20, 2015 1:39 PM:
Thank you very much, Zahar!  I have a working solution now.
