SUPPORT Q&A - Still have problem while adding values for subclass specific properties
myang - Monday, July 27, 2015 1:40 PM:
Hello everyone,
I'm a newer of ARAS.
I've created a class which is a subclass of Part.
And then, i created a specific property on this class.
I got this error message in part creating form just after selecting type:
Resource with key = "'class_spec_field.Part_AF_Pylon'" is not found.
I've already modified file "InnovatorClientSolutionsPLMxmlui_resources.xml"
with adding this line
<resource key="class_spec_field.Part_AF_Pylon" value="Pylon"/>
Actually, i checked last accessed date of this file, anyway, it hasn't been red when aras launched.
I also applied "Clear Client metadata Cache" and Rebuild keyed names.
The screenshot of the problem is attached.
Thanks in advance!
