handpuppet - Tuesday, July 28, 2015 12:59 PM:
I am looking to either disable the add new and delete buttons on the toolbar, or through an event with a method, catch when the user tries to create new or delete and deny them access to do that. I already have the code to check to see if a user is in a particular identity. I just need to know how to stop a user from deleting when they click the red X button and stop from creating new
JensRollenmueller - Friday, July 31, 2015 4:02 AM:
prevent deletion:
- simply write a Server method and add this as "OnBeforeDelete" on the Item. You can use c# or VB.nat to write the code.
prevent add:
- To prevent add you have 3 different options:
a) Simply use "Can Add" within the Item to prevent adding of items based on different properties.
b) Client Method on the Item "OnAdd" - this will prevent adding "before" the form will show up
c) Server Method on the Item "OnBeforeAdd" - this will prevent adding Item when you try to hit the save button within a form:
Here you will have the option to validate properties on the form and prevent adding it based on values of properties
Jens
