[email protected] - Thursday, August 13, 2015 8:10 AM:
Hi
Do any of you have an idea how to order parts on the BOM relationship by item_number.
A lot of our users requests BOMs sorted by item_number. I have tried changing "Order By" attribute on sort_order (sequence) property on the Part BOM reationship to "2". On the Part itemtype I have checked that "Order By" attribute on the property item_number is set to "1".
I would assume above settings would make the Part BOM relationship order by item_number but it doesn't seem to work that way.
Any idears?
We are on Aras10 SP4.
Kind Regards
Henrik Olesen
Kamstrup A/S
Denmark
Dave_Rollinson - Wednesday, August 19, 2015 5:13 AM:
Hennrik
You could add a Server Event to ItemType "Part BOM" as "OnBeforeGet" to modify the "sort_order" attribute.
C# code for the Method would be:
this.setAttribute("sort_order","item_number");
return this;
This will then change the sort order for any search of Part BOM Items.
[email protected] - Wednesday, August 19, 2015 8:13 AM:
Hi Dave
Thank you for your reply.
I have tried creating a server event and added it as OnBeforeGet og Part BOM itemtype just as you described but it doesn't change anything.
Even if I press refresh on the form or push the search button the BOM is still not sorted.
Do you have any suggestions?
We are running Aras10SP4.
Dave_Rollinson - Thursday, August 20, 2015 4:00 AM:
Henrik
I tested in V11 SP2 and it worked; but after your comment I also tested in 10 SP4 and it didn't work.
I will follow up with a test in 10 SP5 if that helps.
A workaround could be to use a Server Event to re-write the "sort_order" property for all "Part BOM" Items for a Part ("OnAfterAdd" and "OnAfterUpdate" for the Part ItemType).
[email protected] - Thursday, August 20, 2015 5:27 AM:
Hi Dave
Thank you very much for you effort. I appreciate that.
We have just upgraded our environments to SP5 and ufortunately it doesn't seem to work in Aras 10 SP5 neither. I have just tested.
I'm a novice concerning coding and I'm only capable of cypy pasting code and making small modifications to existing methods so I'm not really sure I understand your workaround. Neither will be able to create the code by myself.
I will probably raise this to Aras as a support issue since I guess it must be a system bug.
Regards
Henrik
