troques - Wednesday, September 2, 2015 10:01 AM:
When I try to add a new file, I have an error message "The operation is not functionnal because the .NET controls are not available.".
Could you explain me how to solve it please ?
edmoreirabr - Monday, September 7, 2015 12:55 PM:
Roques,
Did you setup the .NET security por IE?
What´s the Aras Innovator version you're trying to do this action?
Edson
troques - Tuesday, September 8, 2015 3:43 AM:
Mr Moreira,
If you are talking about the document "Client Setup for IT on Windows", Yes I did it. Otherwise, could you explain me the approach ?
Aras Innovator 11.O with IE 10
Tristan Roques
Peter Berger - Wednesday, February 17, 2016 3:17 AM:
Mr Moreira and Mr Roques,
I have exactly the same Problem and nothing seems to help. Without a solution for this Problem i cannot work with Aras Innovater.
I would be very thankfull for help.
I use the Aras Innovator 11.0 with IE 11
Peter Berger
Peter Berger - Wednesday, February 17, 2016 3:24 AM:
i am working on exactly the same problem for days and nothing seems to help. I am just a university student an my group needs Aras Innovator for a project.
It would be very nice, if somebody couldt offer me a solution.
Thanks from
Peter Berger
yh_bg - Tuesday, September 20, 2016 7:05 PM:
Has anyone found a solution to this issue?
I have the same problem. .Net controls not available when attempting to add file attachments. Windows 10 IE11 and Windows 7 IE11
Set EnableIEHosting to 1, ran sdns as admin, tried IE, Chrome, Firefox..., not able to add files to cad documents...
BG
edonahue - Friday, September 23, 2016 4:14 PM:
Hi BG,
What version of Aras are you currently using? Can you confirm that you have added your Aras url to the Trusted Sites list in IE?
yh_bg - Tuesday, September 27, 2016 9:46 PM:
edonahue - Monday, October 10, 2016 1:23 PM:
Hi BG,
It sounds like there may be a configuration issue that is specific to your machine. If you are an Aras Partner or Subscriber, the Aras Support team should be able to help you straighten out the issue. If you aren't a Partner or Subscriber, our Community team will be able to guide you on the next steps to troubleshooting the file upload error.
AbhishekSrivastava - Wednesday, October 19, 2016 6:26 AM:
In explorer 11 and 10 i also face same kind of issue with Aras Innovator 11
Error Message: The Operation is not functional because the .Net Controls are not available.
While dot net framework 4.5 installed on machine.
edonahue - Monday, October 24, 2016 4:59 PM:
Hi Abhishek,
If you've tried all of the tips in this thread and your other threads regarding this error, I'd recommend the same to you as I did to BG.
yh_bg - Monday, October 24, 2016 5:59 PM:
Hi Abhishek,
.Net and IE10 and 11 are painful.
I was able to get 1 machine to work after some advice from Eli.
To get Windows 7 to work, I did a fresh boot to ensure IE was not running and I ran SDNS as administrator. It seems important to ensure IE is not running when you add the URL via SDNS.
Also, make sure you have EnableIEHosting set to 1 in the registry.
And, after all of that, ensure compatibility mode is turned off in IE.
Follow the instructions in this guide;
www.aras.com/.../DocumentView.aspx
Aras 11SP5 is a challenge to get fully functional due to .Net reliance. Worked ok with IE9 after a lot of finageling, but since the IE11 update, I have not been able to get it going on any Windows 10 machines. (Everything works (I think) except attaching files).
I would love to try SP8 which in theory should work with any browser. But I cannot convince my boss to subscribe because of all the .Net related issues I have had with demo-ing SP5.
I hope you have better luck than I did. And if you ever come up with a solution to .Net with IE11 on Windows 10, please share with the community.
Thank you,
BG
