Bryanjscott777 - Thursday, September 3, 2015 4:42 PM:
dewing - Thursday, September 3, 2015 4:47 PM:
can u reply back with a screen shot.
-Dave
Bryanjscott777 - Thursday, September 3, 2015 4:58 PM:
Thanks for the reply,
Below is a sceenshot of the window, it doesn't show the description box text being cut off in this example though.
dewing - Monday, September 21, 2015 9:27 AM:
The popup in question is defined by [YourInnovatorServerPathHere]InnovatorClientscriptsInBasketInBasket-VoteDialog.aspx
if you search for that aspx file you will find it called from various other files. For example:
[YourInnovatorServerPathHere]InnovatorClientjavascriptItemsGridInBasketTaskGrid.js calls this code file and sets the size with the following code::
var wndOptions = { dialogHeight: 550 , dialogWidth: 700 };
showModalDialogWithDelay("InBasket/InBasket-VoteDialog.aspx", params, wndOptions);
You would need to modify the files that call the VoteDialog and change the height & Width settings.
D
Bryanjscott777 - Tuesday, September 22, 2015 8:43 AM:
Thank you for the reply David, this answers my original question and may also help with another solution that I have been thinking about.
Unfortunately, as of this writing, I have not been able to locate the InBasket-VoteDialog.aspx or the InBasketTaskGrid.js files, I assume that they are located on the server and I have a request into our IT group for access, I'll provide an update once I can access the files.
I will be attending the Developing Solutions class 10/19 - 10/22 and hope to gain a better understanding of how to search for and modify the required files from the class.
Is it possible to capture an image of the Task portion of the InBasket-VoteDialog.aspx say on a Relationship tab?
Regards, Bryan
dewing - Tuesday, September 22, 2015 9:32 AM:
If you are attending the class in Andover let me know. Ill stop by and say hello.
The files would be on the server - sorry I assumed you had access. They are in {YourServer}InnovatorClient
If you are playing around - why not dload and install the server on your local machine? What you are looking at is part of the free license. (You can use free SQL express)
D
Bryanjscott777 - Tuesday, September 22, 2015 3:18 PM:
I will be attending the class there in Andover, should have my travel itinerary in the next day or so, I look forward to meeting you.
Received access to the files this afternoon so I will start working on them and post an update when I get further along.
I like your idea of loading things local, sure would save time with my testing, I'll get this going in the next week or so...
Thanks David!!!
