DEVELOPERS FORUM - Multilevel BOM with structure using SQL Server Reporting Services
Juriaan - Tuesday, September 15, 2015 3:20 AM:
We have just started implementing aras innovator and I would like to use SQL Server Reporting Services as the prefered reporting solution. Can anyone help me with a SQL based alternative for the "Multilevel BOM Report", included in Innovator? I have been experimenting with the multilevelbom1 and multilevelbom2 sql stored procedure and function, but the resulting report is sorted by level. I would like a report where the structure of the BOM is preserved, like the original Multilevel BOM Report.
Thanks in advance for your help!
DavidSpackman - Wednesday, September 16, 2015 9:55 PM:
I've found CTE as the good method to get a recursive structure.
declare
	@sItemNumber varchar(50),
	@sId varchar(32)
set @sItemNumber = 'Your Part Number'
SELECT
	@sId = [PART].id
FROM
	[innovator].[PART]
WHERE
	[PART].ITEM_NUMBER = @sItemNumber
	AND IS_CURRENT = '1';
WITH RecursiveBOM(SOURCE_ID, RELATED_ID, QUANTITY, indent_level) AS
		SELECT -- anchor member
			pb.SOURCE_ID,
			pb.RELATED_ID,
			pb.QUANTITY,
			0
		FROM
			innovator.PART_BOM pb
		WHERE
			SOURCE_ID = @sId
    UNION ALL
		SELECT -- recursive member
			pb1.SOURCE_ID,
			pb1.RELATED_ID,
			pb1.QUANTITY,
			indent_level +1
		FROM
			innovator.PART_BOM pb1
			--INNER JOIN with the CTE
			INNER JOIN RecursiveBOM rb ON rb.related_id = pb1.SOURCE_ID
SELECT
	indent_level AS [Level],
	sp.ITEM_NUMBER PARENT,
	sp.NAME PARENT_NAME,
	source_id as [PARENT ID],
	rp.ITEM_NUMBER CHILD,
	rp.NAME CHILD_NAME,
	related_id as [CHILD ID],
	rb.QUANTITY
FROM
	RecursiveBOM rb
    INNER JOIN innovator.PART sp ON rb.source_id = sp.ID
    INNER JOIN  innovator.PART rp ON rb.related_id = rp.ID
Juriaan - Thursday, September 17, 2015 4:27 AM:
David,
Thanks for this! It does provide a much better result than I have come up with sofar. The only thing is that the result is sorted by level (additional columns omitted for clarity)
Level Part Number Name
0 D03100-007 WEB
0 TH5-910-2 BONDING POWDER
0 D03100-005 WEB
1 LN9073-3.4374T6-0,4 SHEET
1 LN9073-3.4374T6-0,8 SHEET
And I would like it to be sorted by BOM structure tree, like this:
0 D03100-005 WEB
0 D03100-007 WEB
Any Ideas how to sort the result properly? I am sure there should be something possible using the childs and parents in the current result to create a sort order.
Many thanks in advance for your help!
Juriaan
DavidSpackman - Thursday, September 17, 2015 9:21 AM:
I haven’t tested, but maybe this link can help…
Juriaan - Wednesday, September 30, 2015 9:15 AM:
David,
Thanks for your help in pointing me in the right direction! I finally managed to create the report I wanted, using the information found here:
http://social.technet.microsoft.com/wiki/contents/articles/21062.t-sql-hierarchical-table-sorting-with-a-parent-child-relation.aspx
I managed to come up with the working SP below:
USE [InnovatorSolutions]
GO
/****** Object:  StoredProcedure [innovator].[MultiBom_GetCompleteBomNAC]    Script Date: 9/30/2015 3:08:01 PM ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
ALTER PROCEDURE [innovator].[MultiBom_GetCompleteBomNAC] (@partId CHAR(32))
AS
BEGIN
-- We need a table variable to add the the selected part or assembly to the BOM report later
DECLARE @tempbom TABLE (
ID VARCHAR(32),
SOURCE_ID VARCHAR(32),
QUANTITY INT,
SORT_ORDER VARCHAR(32),
RELATED_ID VARCHAR(32),
PATH VARCHAR(MAX),
LEVEL INT,
XR FLOAT(53));
-- Use CTE to create the multilevel BOM
-- The [path] column explains the level the (sub)part is in the hierarchy (can be left out)
-- The level column counts the level in the BOM
-- The xr column is a numeric field for the BOM sorting
  WITH BomTree (id, source_id, quantity, sort_order, related_id, [path], level, xr)
AS
SELECT
    ID,
 SOURCE_ID,
 QUANTITY,
 SORT_ORDER,
 RELATED_ID,
    CAST(ROW_NUMBER()over(partition by source_id order by sort_order) as VARCHAR(MAX)) as [path],
    1 as level,
    ROW_NUMBER()over(partition by source_id order by sort_order) / POWER(10.0,0) as xr
FROM PART_BOM
WHERE source_id = @partId
UNION ALL
SELECT
 t.ID,
    t.SOURCE_ID,
 t.QUANTITY,
 t.SORT_ORDER,
 t.RELATED_ID,
    [path] +'-'+ CAST(ROW_NUMBER()over(partition by t.source_id order by t.sort_order) as VARCHAR(MAX)),
    level+1,
    xr + ROW_NUMBER()over(partition by t.source_id order by t.sort_order) / POWER(10.0,level+1)
 FROM
    BomTree
 join PART_BOM t on BomTree.related_id = t.source_id
We need to add the selected part or assembly as top level of the BOM.
Since we cannot reference a CTE table more than once, a
table variable is used here
INSERT INTO @tempbom
SELECT *
FROM BomTree
Adding the selected part at the top of the BOM tree.
Source ID is set to zero, because the part or assembly has no parent
SELECT ID, '0' as SOURCE_ID, QUANTITY, SORT_ORDER, RELATED_ID, '0' as path, 0 as level, 0 as xr
FROM PART_BOM
WHERE RELATED_ID = @partId;
Create the BOM report output, while querying the
required details from the PART and PART_BOM tables
You can add additional columns from the PART and PART_BOM tables here, as needed
 SELECT sp.id source_id, sp.item_number source_number, sp.name source_name,
        pb.quantity quantity, pb.sort_order sort_order, pb.id bom_id, pb.remark related_remark,
        rp.id related_id, rp.name related_name, rp.item_number related_item_number, rp.classification related_classification,
  cb.path path, cb.level level, cb.xr xr
  FROM @tempbom cb LEFT JOIN PART sp ON cb.source_id=sp.id
         LEFT JOIN PART_BOM pb ON cb.id=pb.id
         LEFT JOIN PART rp ON cb.related_id=rp.id
  ORDER by xr --sort the BOM in the correct order
END
