eknath - Tuesday, September 22, 2015 7:27 AM:
Hi all,
I want to import Excel data to an Item Type..
any solution plz help me
thanks in advance
John Example - Tuesday, September 22, 2015 8:16 AM:
Hi eknath,
For your needs you can use OleDB within Server-side method. For example you can grab data from .xlsx into dataSet this way:
public static DataSet getExcelData(string filePath, string sheetName)
string sql = "SELECT * FROM ["+sheetName+"]";
string excelConnection = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" + filePath + ";Extended Properties=Excel 12.0;";
using (OleDbDataAdapter adaptor = new OleDbDataAdapter(sql, excelConnection))
DataSet ds = new DataSet();
adaptor.Fill(ds);
return ds;
Then you just need to create new Items for each row you'll get.
Btw, do not forget to add System.Data.OleDb reference to a method-config.xml file (C:Program Files (x86)ArasInnovatorInnovatorServer).
zahar - Tuesday, September 22, 2015 8:25 AM:
· Write your own application that will parse the Excel and import into Aras using IOM
OR
· Use a tool we wrote to import any data from Excel to Aras using a simple GUI interface. Please contact Sagi - He is handling this tool - [email protected]
