DEVELOPERS FORUM - Creating BOM with multiple parts
John Example - Tuesday, October 6, 2015 11:04 AM:
Hi everyone,
I need to add multiple parts to BOM structure. Instead of this my method adds only the first Item from each table to a parentItem.
I have the following code:
parentItem = CreateNewItem(ref inn, "Part", parentItemNumber.ToString(), parentItemName);
parentItem.apply();
for (int j= 0; j < rowsCount; j++)
string firstrowvalue = dataSet.Tables[i].Rows[j][0].ToString();
string secondrowvalue = dataSet.Tables[i].Rows[j][1].ToString();
string thirdrowvalue = dataSet.Tables[i].Rows[j][2].ToString();
Item bomItem = inn.newItem("Part BOM","add");
bomItem.setProperty("quantity", secondrowvalue);
Item relatedItem = inn.newItem("Part","add");
relatedItem = CreateNewItem(ref inn, "Part", firstrowvalue, thirdrowvalue);
parentItem.setAction("edit");
bomItem.setRelatedItem(relatedItem);
parentItem.addRelationship(bomItem);
Item resultItem = parentItem.apply();
I double checked variable rowsCount and it's OK. Any suggestions where I could mess up?
Thank you in advance.
