DEVELOPERS FORUM - Facing error during Aras integration with SharePoint
kripa - Monday, October 26, 2015 9:00 AM:
Problem: I am not able to create External List into SharePoint site. it gives following error:
MethodInstance with Name 'ReadList' on Entity (External Content Type) with Name 'PartEntity' in Namespace 'Rzrlf.SP.Innovator.Bdc.PartBdcModel' failed unexpectedly. The failure occurred in method 'ReadList' defined in class 'Rzrlf.SP.Innovator.Bdc.PartBdcModel.PartEntityService' with the message 'The type initializer for 'Aras.Net.ApplicationRequestProvider' threw an exception.'.
Explanation: I have installed Aras Innovator 11.0 successfully. and then after I had download solution from https://plm.codeplex.com/SourceControl/latest#README.txt here.
and follow the steps as per documentation which is download from Home page under Kit Contents .
I am not able to create external list into SharePoint. It gives me above error.
Please guide me ASAP.
Kripa Dharasandia
