END USER TIPS & TRICKS - Date format in the Properties View
BoG.Nielsen - Tuesday, October 27, 2015 10:29 AM:
I am using Aras Innovator 10.0 SP3 Build: 5926.
I want to change the date format shown in the Properties View in the two columns of 'Created On:' and 'Modified On:'.
I am using:
IE language preference English (United States)[en-US]
Region and Language format English(United States) having the following date format:
Short date: M/d/yyyy
Example: 27. October 2015 -> 10/27/2015
The date format in the Properties View in the two columns of 'Created On:' and 'Modified On:' is like this
10/27/2015
This I want to be displayed like the default Danish time format:
27-10-2015
In the Aras documentation (Configuring Internationalization.pdf) I find:
5.1.3 Locale Neutral Data Formats
Date, decimal, and float properties will be displayed in the Aras Innovator UI based on the patterns in the client sessions Regional and Language settings...
Based on this information I have changed the Region and Language format into Danish(Denmark) having the following date format:
dd-MM-yyyy
Example: 27. October 2015 -> 27-10-2015
Starting the Aras UI the date format in the Properties View is still 10/27/2015 and thereby not changed as expected.
Obvious I am missing something.
Any helpful guideline will be appreciated.
