flo - Monday, January 25, 2016 11:49 AM:
How can I add a new property of type boolean and name "test" to an existing item in a server-side C# method? The property should not be created in the itemType editor before the method is called. Once the property is created, how do I make it visible in the grid, when the item gets found? I am using Aras Innovator 11.0 Build 6073.
rneuber1 - Monday, February 1, 2016 6:52 AM:
Maybe you could describe a little bit more what you are trying to achieve?
Sounds a bit weird, although it should be easy to add an ItemType in a server-side method.
Ralf
flo - Monday, February 1, 2016 9:08 AM:
The OnAfterGet event of my ItemType calls a server-side C# method. In that method I want to add a new property to the item in order to display a value calculated by that method in the grid of search results. However, I don't want to add that property to the Itemtype of the item permanently.
DavidSpackman - Monday, February 1, 2016 9:21 PM:
Hi Flo,
Have you looked into properties of type federated? No data is stored in the database for these types of properties.
This wiki page might help you http://www.aras.comhttp://www.aras.com/Community/wikis/kb/how-to-use-federation.aspx
Regards, David
