SUPPORT Q&A - Error with Client
Harris - Thursday, January 28, 2016 9:17 AM:
I have done the installation of Aras 11.0 on Windows server 2012 using the installation guide. I follow all the steps in that guide and I completed the installation.
My problem is the fact that when I write "localhost/InnovatorServer" in the adress bar of mozilla 31.0. I get an error named "Servor Error in 'InnovatorServerClient'  application " and I don't know where this error come from and how to resolve it.
For more precision about that error please take a look at the attachement.
Thanks in advance for your help.
gks - Friday, February 5, 2016 5:30 AM:
This can have multiple causes:
  • Not the correct .Net Framework installed
  • .Net Framework has some problems
  • .Net Framework not correctly enabled in  IIS
  • IIS not correct set up (not all required features enabled)
Interesstingly this error has normally nothing to do with the Aras Innovator itself, more with the underlaying systems.
My suggestion is to format and install everything again. Or to check the above mentioned points.
