SUPPORT Q&A - Installer Cannot Connect to Database
Bryan - Tuesday, November 4, 2008 11:21 AM:
The aras installer isn't able to connect to sql.  The sql instance has sa enabled and the same password I'm entering in aras.  I've uninstalled and reinstalled the sql instance and the settings appear to be correct.  Other instances on the sql server are functioning with other applications.  I tried to connect to some of those instances as well and it doesn't work.  Could someone please give me some pointers.  Running SQL Server 2005, Windows Server 2003 Enterprise, SQL Server Management Studio installed.  Below is a screenshot of the error message.Installer Error.
