AbhishekSrivastava - Thursday, February 11, 2016 1:27 AM:
Hi friends ,
I am facing an error while making multiple vault.
Error as shown below:
I follow step by step below procedure:
- We Allocate a server at the secondary location (Site 2) that is capable of running Windows Internet Information Server (IIS) and has sufficient available storage to house the vaulted files.
- Run the Innovator setup, InnovatorSetup.msi, to begin the installation process.
- Perform a custom installation and select the Vault Server setup component only.
- Choose a name for the vault. The default name in the installation is “Default”. I already have a vault named “Default” in our Innovator environment, so I should specify a different name. A name indicating the location can be helpful when looking at a list of Innovator vault names.
- The installation will also ask for the Application Server URL. This is the URL to the Innovator server instance at Site 1. The URL has the following form, http://<Site_1_Hostname>/<web_alias>/Server/InnovatorServer.aspx.
- Identify the local path on the server where the vaulted files will be stored.
- Complete the installation.
- Browse the installation path and open the file VaultServerConfig.xml in a text file editor. Confirm that the <AppServerURL> (from Step 5) and <name> (from Step 4) parameters are correct per the values entered during the installation.
- Login to Innovator as an administrator and expand the Administration -> Vaults branch of the tree.
- Add a new vault record.
- Set the Name on the form to the vault name used during the installation (Step 4).
- Set the Vault URL to http://<Site 2 Hostname>/vault/VaultServer.aspx.
- Save, unlock and close the Vault record.
- Update the Default Vault value on the user records that will be using the Site 2 vault.
- Login as one of the Site 2 users and create a new document object and attach a file to it. Unlock the document object.
- Confirm that the file has been added to the Site 2 vault in the path specified in Step 6.
If any solution then please share:
Thanks in advance
Abhishek Srivastava
AbhishekSrivastava - Sunday, February 21, 2016 11:08 PM:
Dear Friends ,
It is very urgent , if have any solution then kindly request to share me .
Abhishek Srivastava
fli - Monday, August 22, 2016 8:59 AM:
Did you find a solution?
-Christoffer
AbhishekSrivastava - Wednesday, September 14, 2016 4:28 AM:
Dear Christoffer,
Not yet found any solution , and little bit confused that it was paid or Open License for Multiple Vault.
If you know then please share your views.
Thank You
Abhishek Srivastava
edonahue - Monday, September 19, 2016 12:59 PM:
Hi Abhishek,
Vault replication is a subscription feature in Aras Innovator, but you should still be able to have multiple vaults configured without a feature license.
Please confirm the following information about your environment:
- Version of Aras Innovator
- Browser & browser version
- Size/type of the file you're trying to save
- Whether the issue occurs for all users, or only users with Default Vault set to the secondary vault
AbhishekSrivastava - Tuesday, September 20, 2016 7:31 AM:
Dear Eli Donahue,
Please find out the below information as you asked....
Aras Version is 11.0 SP2
Browser Mozilla Firefox 31.8 ESR or Explorer 11
File Size in KBs
Issue Occur for all User.
Thank You
Abhishek Srivastava
