SOLUTION - PROGRAM MANAGEMENT - How can i make attachment is mandatory
AbhishekSrivastava - Friday, February 12, 2016 4:58 AM:
When we fill all fields in form and forgot to attach physical file and going to save an item then system not accept. So i want that attachment should be required.
But how can we do that above query , kindly share me the solution.
Thanks in advance
Abhishek Srivastava
rneuber1 - Friday, February 12, 2016 10:26 AM:
In the Relationship type, you can set "min occurs" to "1", then you have to add at least one attachment:
Ralf
AbhishekSrivastava - Friday, February 19, 2016 11:34 PM:
Thank You rneuber1 ,
It works.  Also need one help if i want edit on error message then how will i do it?
Thank You
Abhishek Srivastava
