TobiasCzempiel - Tuesday, March 22, 2016 11:01 AM:
I'am trying to install Aras Innovator 11 on my Windows 8 Machine.
While running the InstallationWizard i get the first Problem while configuring the databse.
After clicking "Ok" the "Next" Button in the Wizard is still not available.
When I open the SQL Server Management Studio i can see a new InnovatorSolution Database.
With that option I can click the "Next" button and the Wizard finishes the Installation as expected.
The issue apppears when I try to log into Aras (using both IE and Firefox):
I get the following error. Sorry that the language is German but I will try to explain the German parts.
The Database is not available: running as Databaseprinzipal is not possible,
because the Prinzipal 'aras_innovator' is not there,
for this Type of Prinzipal is no Idetity change possible,
or you have not necessary rights.
Do you have any suggestions what I could do to solve this issue? I tried a couple of things without success.
Greetings
TobiasCzempiel - Tuesday, March 29, 2016 1:45 AM:
I solved my Problem by using the full Microsoft SQL Version instead of the SQL Express Version. I really thought that the difference between those two is just in the available size, i think Express is limited to 10 GB, but it is not working with Express Version.
Greetings
rneuber1 - Tuesday, March 29, 2016 4:32 AM:
This happened to me, too during installation of SQL Server express.
I had chosen "Windows authentication" first, which seems to be the cause of this issue. I reinstalled it
with "password authentication" and set a password for the "sa" user. This works and now I have running Aras with SQL Server Express.
TobiasCzempiel - Tuesday, March 29, 2016 5:16 AM:
I reinstalled it with "password authentication" and set a password for the "sa" user. This works and now I have running Aras with SQL Server Express
I don't know if i choose the SQL Server and Windows-authentication while installing SQL Express, but it shouldn't make a difference in behaviour if you configuere it after installation ... right?!
I will try if your solution works for me.
Greetings
