SOLUTION - PROGRAM MANAGEMENT - How to set two filter in a dropdown field in aras
AbhishekSrivastava - Tuesday, March 29, 2016 3:38 AM:
Dear All,
If I want to Set two filter in a dropdown field then how it will done by filter list concept.
1st field : Project Name    (FilterList1)
2nd Field : Department     (FilterList2)
3rd Field: Similar Project Name. (Result)
Now 1st field is 1st filter and 2nd field is 2nd filter. Project Name Data Type is "string" and Department Data Type is Classstructure.
So Can you please share solutions if any body have.
Thanks in Advance
Abhishek Srivastava
Yoann Maingon - Tuesday, June 14, 2016 5:23 AM:
Have you tried fieltered list already?
How far did you go?
edonahue - Wednesday, June 15, 2016 11:19 AM:
Hi Abhishek,
Can you confirm the type of the third field? Are you trying to programatically fill the third field based on the first and second field, or are you trying to create some kind of input validation or search criteria?
