SOLUTION - PROGRAM MANAGEMENT - How to print Gantt Chart in Aras 11.
AbhishekSrivastava - Friday, April 1, 2016 7:03 AM:
How to print Gantt Chart in Aras,
Is there any way to print?
If anyone have solution then kindly share ....
Thank You
Abhishek Srivastava
Abhijit - Monday, June 13, 2016 8:22 AM:
Hi Abhishek,
Open the Gantt chart by clicking highlighted Gantt icon
Then you will see a printer icon on chart on top left corner which calls print command or may save as a file (mostly PDF)
I am using ARAS 11 with SP5
Abhijit
AbhishekSrivastava - Monday, July 18, 2016 2:49 AM:
Thank Abhijit,
Actually I am using 11.0 SP2 and in this version i am unable to print Gannt Chart , So Is there any way to modify in SP2 or there is only one way to modify in SP5.
I think there is definitely some way to do like programmatically , so can you please help over this.
Abhishek Srivastava
edonahue - Monday, July 18, 2016 10:49 AM:
Hi Abhishek,
If you are running into trouble printing your Gantt chart, there is a workaround that may help. Open up your project, click the View dropdown in the relationship toolbar.
The Gantt chart will then appear in the relationship grid, which you can then print. If your project is very large, you may need to resize the window and take a screenshot to capture all or most of the content.
AbhishekSrivastava - Saturday, July 23, 2016 12:16 AM:
Dear .
I agree your solution,
I know how to view Gannt Chart from Project but when i click to print then it will not taken complete copy of gannt chart.
I think Snapshot is not the right way , You have any method like Reports to print gannt chart from project Because normally its not perfectly print a complete copy.
Thanks Dear
Abhishek Srivastava
edonahue - Monday, July 25, 2016 2:41 PM:
Hi Abhishek,
The screenshot suggestion is just a workaround in case you have a large Gantt chart that doesn't easily fit on one page. The "correct" approach for 11.0 SP2 is to expose the Gantt chart in the relationship grid as described above, and then use the Print button in the relationship grid toolbar to print/save as PDF. This is similar to the approach recommended by Abhijit above.
