ejmoska - Thursday, April 21, 2016 7:06 AM:
We have recently installed component engineering solution
The image that should display the register button is not showing (No images, like broken links or something)
Cloud search returns webpage not found error.
Is the component engineering supposed to be not working at all on 11.SP5?
Thank you
ejmoska - Friday, April 22, 2016 5:26 AM:
So we have figured it out, the installation instruction is not complete. You need to copy/paste the CE innovator/client data into server's innovator/client folder.
The register button and all appeared after, but when trying to register we receive errors.
Internal Server ErrorAras.Server.Core.InnovatorServerException: Database Name Or Database Description Is Wrong.
(Check your request and server configuration file)
at Aras.Server.Core.Utilities.RollbackTransactionsAndThrowException(String faultString) in d:BuildsInnovator.Builds6296-Innovator-RELS11-0-SP5InnovatorCompilableCodeCoreUtilities.cs:line 328
at Aras.Server.Core.DB.InitDataBase() in d:BuildsInnovator.Builds6296-Innovator-RELS11-0-SP5InnovatorCompilableCodeCoreDBClassesDB.cs:line 94
at Aras.Server.Licensing.LicenseManagerRequestController.InitializeDatabaseAndAuthentificate() in d:BuildsInnovator.Builds6296-Innovator-RELS11-0-SP5InnovatorCompilableCodeCoreRequestControllersLicenseManagerRequestController.cs:line 17
at Aras.Server.Licensing.LicenseManagerWebService.GetServerInfo() in d:BuildsInnovator.Builds6296-Innovator-RELS11-0-SP5InnovatorCompilableCodeCoreLicensingLicenseManagerWebService.cs:line 91
I suppose these errors are due to incompatibility of CE 11R1 to Aras 11SP5. are there any work-arounds available? maybe a hotfix planned in near future?
