APPLICATION - PRODUCT ENGINEERING - How to add ULR to items into emails
tobias - Monday, November 24, 2008 9:54 AM:
I am working with workflows and I noticed there is only 1 email-template with a universal but simple format.
I think adding new templates would be easy. But, what I would like to do is to insert a URL to the controlled item of a workflow.
what are the queries and variable to be used for this ?
what is the format of a URL that can be called from outside Innovator (from the email message or another client) and which navigates directly to the identified item after log on ?
Tobias
RobMcAveney - Monday, November 24, 2008 10:21 AM:
Hi Tobias -
The format of the URL is:
http://[server]/[innovator]/Client/default.aspx?StartItem=[itemtype]:[id]
for example:
localhost/.../default.aspx
so in the body of the email you can make the item number a link, like this:
<p><font size="+0" style="font-variant: small-caps">${Item[@type="ItemType"]/label}:</font> <a href="">localhost/.../default.aspx
Hope that helps -
Rob
tobias - Tuesday, November 25, 2008 5:28 PM:
Rob,
thank you very much for you quick response. This is exactly the information I needed.
Would be nice to have this in the standard email template. Or perhaps keep the existing template and add a second one with the URL.
-Tobias
