SUPPORT Q&A - Microsoft . net framework error after login when app starts to run
wfbeck - Friday, December 12, 2008 2:59 PM:
error 401 unauthorized.  running win xp sp2, ie7, .net 3.5
I tried turning off proxy settings but that did not fix it.  I ran the little .net tool from the website and that did not fix it.
details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Net.WebException: The remote server returned an error: (401) Unauthorized.
   at System.Net.HttpWebRequest.GetResponse()
   at System.Xml.XmlDownloadManager.GetNonFileStream(Uri uri, ICredentials credentials)
   at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials)
   at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
   at System.Xml.XmlTextReaderImpl.OpenUrlDelegate(Object xmlResolver)
   at System.Threading.CompressedStack.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.CompressedStack.Run(CompressedStack compressedStack, ContextCallback callback, Object state)
   at System.Xml.XmlTextReaderImpl.OpenUrl()
   at System.Xml.XmlTextReaderImpl.Read()
   at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
   at System.Xml.XmlDocument.Load(XmlReader reader)
   at System.Xml.XmlDocument.Load(String filename)
   at Aras.Client.Controls.MainMenu.XMLMenuAppletDeclarator.run(MainMenu menu, String RelativePath)
   at Aras.Client.Controls.MainMenu.MainMenu_StartEventHandler(Object sender, EventArgs e)
   at System.Windows.Forms.UserControl.OnLoad(EventArgs e)
   at System.Windows.Forms.UserControl.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.UserControl.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ActiveXImpl.System.Windows.Forms.IWindowTarget.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Utils
    Assembly Version: 9.0.1.5430
    Win32 Version: n/a
    CodeBase: localhost/.../Utils.DLL
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.mshtml
    Assembly Version: 7.0.3300.0
    Win32 Version: 7.0.3300.0
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
Vault
    Win32 Version: n/a
    CodeBase: localhost/.../Vault.DLL
Calendar
    Win32 Version: n/a
    CodeBase: localhost/.../Calendar.DLL
IOM
    Win32 Version: n/a
    CodeBase: localhost/.../IOM.DLL
TreeTable
    Win32 Version: n/a
    CodeBase: localhost/.../TreeTable.DLL
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
StatusBar
    Win32 Version: n/a
    CodeBase: localhost/.../StatusBar.DLL
MainMenu
    Win32 Version: n/a
    CodeBase: localhost/.../MainMenu.DLL
Toolbar
    Win32 Version: n/a
    CodeBase: localhost/.../Toolbar.DLL
ColorDialog
    Win32 Version: n/a
    CodeBase: localhost/.../ColorDialog.DLL
CustomMarshalers
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Bill - Tuesday, February 3, 2009 6:43 PM:
The error is most likely a proxy setting, but it may not be in your control.  Some networks use Web Proxy Servers that requires all requests to be authenticated as you.  (I worked with a Blue Coat machine once).  Some of the requests from client to server will fail to have these credentials.  I would recommend asking your IT department if such settings are in place.
-Bill
See also: http://www.aras.comhttp://www.aras.com/Community/forums/thread/405.aspx
