solidcad - Sunday, February 1, 2009 9:52 PM:
Hi
I have imported the scoreboard in to my Aras 9.01 version.
I am not able to create a new one. How will i use this solution?
Can anyone clarify?
srii
solidcad - Sunday, February 1, 2009 9:54 PM:
Hi
I am sorry it is ScoreCards. The new add on solutions.
srii
PeterSchroer - Monday, February 2, 2009 2:12 PM:
Hello Srii,
The Supplier Scorecard is linked to the Manufacturer ItemType, nd requires at least one Plant Location.
I am not sure what your problem is, but try this:
1) create a new Process --> Plant Location named Singapore. If you get an error creating this, it is because your logon is not a member of the group Process Planning. Once you can create at least one Location, we can continue.
2) Create a new Sourcing--> Manufacturer and save it. On the ScoreCards tab of Manufacturer, insert a new row. Save the Manufacturer, and then you can open the Scorecard. You see ~10 standard evaulation criteria, and a column for each Plant Location.
solidcad - Monday, February 2, 2009 9:18 PM:
Hi Peter
Thanks. Now i could view the scorecard detail.
srii
