rcrotti - Tuesday, February 17, 2009 7:05 AM:
Hello all,
I just completed the installation of Innovator on a VMware virtual machine running Windows 2003R2 ans SQL Express 2005. All went well during the installation but when I try to connect to the application I obtain the following message:
****** Wrong Soap message *** error:
Server error in 'IInnovatorServer/Server' Application
Error code: -1072896766
Any idea?
Thanks in advance
Dan Turk - Thursday, March 5, 2009 12:01 PM:
Greetings,
I too have received the same error with a bit different scenario. We installed Aras on a fresh install of Server 2008 with .net 3.5. At first I had a very difficult time getting the log-in to even come up. After following the instructions in the Aras .net manual, I was able to correct most of the initial issues. The next problem I had is similar to annother entry and that is I would enter admin and innovator, but nothing would happen. n addition the login and cancel buttons were not properly displayed.
I resolved that issu by loading IE 8 on the computer. now I am past the above mentioned hurdels, however I now receive the
Any ideas would be greatly appreciated,
Dan
ross - Thursday, March 19, 2009 5:07 AM:
Innovator doesn't able to work under IE8 at all. And it will not able to it in the nearest future.
Only in campatibility mode. Give me more information about your system and tell me when you recive this message. And I'll try to help you.
