DEVELOPERS FORUM - Getting report name from client method
jenC - Monday, March 30, 2009 5:34 PM:
I have several different reports that I want to run the same javascript method because they basically all do the same thing.  There is one difference though depending on which report they run.  I cannot find a way in my javascript client method to figure out which report was run in order to handle them slightly differently.
Any help figuring out which report I ran would be greatly appreciated.  I've tried adding content to the Report Query without luck.
We're running 8.1.1 currently (planning on upgrading to 9.1 as soon as possible)
SamsAn - Tuesday, April 21, 2009 2:59 AM:
Hi.
Unfortunately, there are no standard API to retrieve a running report name. But I used the code below to get the report name in its javascript method  (it works in 9.1):
var reportName;
try
  var c = arguments.callee.caller;
  var cntr = 0
  while (c && c.toString().indexOf("function Aras_runClientReport")!=0 && cntr<10)
    c = c.caller;
  if (c && c.toString().indexOf("function Aras_runClientReport")==0)
    reportName = top.aras.getItemProperty(c.arguments[0], "name");
catch (ex)
  reportName = undefined;
if (!reportName)
  top.aras.AlertError("Internal Exception: Cannot define selected report name.");
  return "";
