APPLICATION - PRODUCT ENGINEERING - The issue about the message "The Activity Assignment is not specified and the Activity is not Automatic"
Robin Bai - Tuesday, April 28, 2009 11:08 PM:
I defined a very simple workflow that is Start activity -> Review activity -> End activity.
1. Now a part is in the Review and I want to move the part to next activity End, but system raise a error message  "The Activity Assignment is not specified and the Activity is not Automatic".
2. So I modify the End activity, make the End as automatic activity and remove all related assignment as well.
3. When I back to the Review activity and try to move the part to activity End, the same error message was raised again.
What the root cause of this problem?
RobMcAveney - Wednesday, April 29, 2009 8:19 AM:
Did you start a new Workflow after you made the edit?  Changes to the Workflow Map are not normally propagated to instances that are already running.  You would have to edit the running Workflow Process separately.
Rob
