END USER TIPS & TRICKS - Date Formats
chintsys - Monday, March 5, 2007 9:40 PM:
Is there a way to change the date format from mm/dd/yyyy to either dd/mm/yyyy or d-mmm-yyyy in the Portfolio/Projects table (as well as other tables and forms with dates)?  There does not seem to be a setting available under Administration/Preferences.  Am I looking in the wrong area?
I'm using Aras Innovator 8.1.0 build 5338
thanks,
chintsys
SamsAn - Wednesday, March 7, 2007 5:23 AM:
The following steps setup the required format:
1. Login as admin.
2. Select AdministrationItemTypes in TOC (the main Innovator tree).
3. Find Project in the appeared grid and edit it.
  -> The Project window appears.
4. Select date_start_sched (the date property example, its label is Sched Start) property in Properties tab.
5. Set Pattern=dd.MM.yyyy (for example) for the selected property. Other patterns may be used here.
6. Click Save icon in the window.
7. Select PortfolioProjects in TOC.
  -> Sched Start values are displayed in the specified format.
Note: Sched Start dates are displayed in the specified format on Project form too.
Note 2: This way is useful to change a date property format for any ItemType (Project ItemType is an example).
chintsys - Friday, March 9, 2007 7:00 AM:
Thanks for your clear response.  That worked fine for me.
chintsys
