jmidc - Thursday, May 21, 2009 11:08 AM:
I did an install of Aras on a Windows server 2008 and setup my client on a Windows 7 system. Everything seemed to install properly however when I attempt to access the system I receive an error of "Server Error in '/InnovatorServer' Application.". If I look at the event log on the server I see an error that seems to indicate that the virtual directory isn't set as an application ... but if I take a look in IIS at the InnovatorServer virtual directory it is set as an application "Aras Innovator AppPool ASP.NET 2.0". Any help would be appreciated!
Event Info from server:
Exception information:
Exception type: ConfigurationErrorsException
Exception message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (C:Program FilesArasInnovatorInnovatorclientweb.config line 13)
Request information:
Request URL: plm/.../default.aspx
Request path: /innovatorserver/Client/default.aspx
User host address: 172.16.11.2
User:
Is authenticated: False
Authentication Type:
Thread account name: NT AUTHORITYNETWORK SERVICE
Server - Windows 2008
DB - Existing SQL 2005 Server
Client - Windows 7 / IE 8
Anonymous - Thursday, May 21, 2009 11:21 AM:
1) Windows 7 RC and/or BETA are not a supported client operating systems, and so I do not know if Aras Innovator will load on your client properly.
2) You should check your Roles and Featues for IIS, to ensure you have enabled ASP and ASPX pages in your installation.
Try browsing to this URL to confirm that your installation is running at all:
plm/.../mini-diag.htm
plm/.../innovatorserver.aspx
Do either of these pages load?
-Chris
fgarbin - Wednesday, March 9, 2011 5:56 PM:
I'm trying install Aras to try and have the same problem that you..
Did you solve it ?
I'm using:
Windows 7 Professional
SQL 2008 R2 Express
IIS 7.5
Thanks..
authentic - Monday, August 15, 2011 3:50 AM:
nbnTiger2:
Christian Louboutin UK is here waiting for you with open arms. A lady with a high temperament would love the Christian Louboutin Shoes. Those are the the kind of shoes like the Christian Louboutin Bridal that will distinguish you from others and make you unique and the centre of the spotlight. Ladies have been working just as hard, if not harder, like their male colleagues, so, they should learn how to treat themselves to the best Louboutin Peep Toe that the world has to offer. In any Christian Louboutin Outlet there would be ladies of all ages swarming in to grab a pair of their favourite Christian Louboutin Pumps. The choice of the majority could not be wrong for sure. The Christian Louboutin Wedges and the Christian Louboutin Slingback are a great choice this season, trailing a breeze of high and noble air wherever they go, leaving the men inquistive and eyes following them till they disappear in the horizon. The atmosphere wave along with those fabulous Christian Louboutin Boots. Walking and swaying down the road, no one could possibly miss the dazzling light coming from the Christian Louboutin Sandals on your feet. You leave the man wondering where this dazzling lady came from and the woman all green in the eye. Not to disappoint the men, Christian Louboutin Men have been introduced to satisfy the men.
jmidc - Thursday, May 21, 2009 12:09 PM:
1) I've tried with an XP/IE7 client and the same error was generated.
2) All components of the Web Server (IIS) role are installed except for IIS6 support.
plm/.../mini-diag.htm loads fine but using the diagnostic links generate the same error as plm/innovatorserver/
plm/.../innovatorserver.aspx generates the same error.
I saw that you are certified for 2008 ... are there any specific install guides for Server 2008 server & IIS7?
