venuadepu - Monday, May 25, 2009 6:48 AM:
whenever I try to create a variable for a workflow activity and save the workflow map, it is showing an error message
Failed to update the Workflow Map with ID 7DA468963E754220B565D0F3FCCDBE09 : Failed to apply the skip action to this relationship: An internal error has occured: The update operation failed: Failed to apply the add action to this relationship: The source item has to be specified in order to add a relationship. .
UpdateItem: UpdateItem: xml: GetRelId: ItemMethods: AddRelationshipEx: Source item for Activity Variable is not specified
at System.Environment.GetStackTrace(Exception e, Boolean needFileInfo) at System.Environment.get_StackTrace() at Aras.Server.Core.XML.SetErrorMessage(XmlDocument xmlDom, Int64 faultCode, String errorMessage, String dbMessage, String serverMessageXml) at Aras.Server.Core.UpdateItem.UpdateItem(XmlDocument itemDom, UpdateItemInstructions instructions, XmlDocument responseDom) at Aras.Server.Core.ApplyItem.ApplyItem_Implementaion(XmlDocument& inDom_, Hashtable& AdditionalItemInfo, XmlDocument& outDom) at Aras.Server.Core.ApplyItem.ApplyItem(XmlDocument& inDom, XmlDocument& outDom) at Aras.Server.Core.Utilities.ApplySoapAction(String& soap_action, XmlDocument& inDom, XmlDocument& outDom, Boolean sec_chk, TextWriter writer) at Aras.Server.Core.Startup.soap_action_dispatch() at Aras.Server.Core.Startup.soap_action_dispatch_errorhandler() at Aras.Server.Core.Startup.innovatorserver_main_dispatch() at Aras.Server.Core.Startup.innovatorserver_main() at ASP.innovatorserver_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) at System.Web.UI.Page.Render(HtmlTextWriter writer) at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) at System.Web.UI.Control.RenderControl(HtmlTextWriter writer) at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) at System.Web.UI.Page.ProcessRequest() at System.Web.UI.Page.ProcessRequestWithNoAssert(HttpContext context) at System.Web.UI.Page.ProcessRequest(HttpContext context) at ASP.innovatorserver_aspx.ProcessRequest(HttpContext context) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) at System.Web.HttpApplication.ResumeSteps(Exception error) at System.Web.HttpApplication.System.Web.IHttpAsyncHandler.BeginProcessRequest(HttpContext context, AsyncCallback cb, Object extraData) at System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr) at System.Web.HttpRuntime.ProcessRequestNoDemand(HttpWorkerRequest wr) at System.Web.Hosting.ISAPIRuntime.ProcessRequest(IntPtr ecb, Int32 iWRType)
can anyone do help?
