Brian - Tuesday, June 2, 2009 12:18 AM:
I have put a 150 activity Project together. I want to print the Gantt chart. I can display it and select print etc. That is OK. It just seems that the print output is a bit primitive. Activities are cut in half (horizontally) and headings are not carried on to new pages.
Am I missing something? Is there somewhere that I can set the format options for the print output? Is there something else I should be doing?
Is there another way of printing the Gantt chart?
Brian - Monday, June 8, 2009 9:24 PM:
In the end I resorted to exporting the Project to MS Project (using the community solution, although I did have to modify the date formats coming from Innovator to have them accepted by MS Project) and printing it from there.
Is there another way I should have done this?
Brian
[email protected] - Tuesday, July 1, 2014 1:35 AM:
Hai,
Is there a way to print gantt chart as it is in actual format(i.e., activity should not carry away to next pages) without using MSproject.
Thank you.
