SUPPORT Q&A - Adding a "unit of measure" to a Part
natek64 - Thursday, March 8, 2007 11:01 AM:
How do you add a new unit of measure under the "Unit" drop-down when creating a part?  We need to have KG as an option.
 TIA,
Nate
RobMcAveney - Thursday, March 8, 2007 11:19 AM:
Hi Nate -
The values in the drop-down are controlled by the "Units" List.  To add new units of measure, log in as an administrator and select "Lists" on the TOC.  Search for the List name "Units" and edit it.  Add KG as a new value and save.  The easiest way to see the change is to just restart the client and then edit your Part.
Regards -
Rob
natek64 - Thursday, March 8, 2007 12:45 PM:
Ah.  Lists.  That makes sense.  I looked too quickly through the Admin TOC
Nate
